Light bulbs between seat`s (tunnel)??
  • AUDIS2avant
    • Jan 2009
    • 670
    • Country: Denmark
    I changed the heater matrix in the car last monday, and when i took the center plastic bit on top of the tunnel up i found some bulbs, one just by the gear-selector (alone) one for the cigaret lighter, and it doesnt seem to be light in the Diff. engage thingy?
    Question is, the bulb @ the selector, where does it belong?
    AND, is there light in your diff. thingy? and i dont mean the button with diff on it
  • Nuvo
    • Nov 2003
    • 3826
    Sounds like you are describing the bulb which illuminates the ash tray?
    • AUDIS2avant
      • Jan 2009
      • 670
      • Country: Denmark
      Ok, could be it, just seem to be a little short tho, could try to pul it a bit?
      • Nuvo
        • Nov 2003
        • 3826
        You shouldn't need to pull it. Maybe you could post a pic so we can get a better idea?
        • AUDIS2avant
          • Jan 2009
          • 670
          • Country: Denmark
          I have to take the thing apart again then and i havent got the bulbs yet
          Will try tomorrow m8
          Any idea about the diff lock plate thingy?
          • Nuvo
            • Nov 2003
            • 3826
            If you are asking if the quattro drive train diagram surrounding the diff switch is back lit then the answer is yes, well at least it should be.
            • AUDIS2avant
              • Jan 2009
              • 670
              • Country: Denmark
              Super, thanx m8
